Author Topic: Distribution mode image - scaling  (Read 8812 times)
Crayox
« on: May 24, 2024, 01:13:52 pm »
Probably obvious but when I use image mode with any of those bitmaps (random bands for instance) how do I control it's UVW or size? It doesn't pick up the objects UVW. Also what's the map then for?
Thx!
Re: Distribution mode image - scaling
« Reply #1 on: May 24, 2024, 01:19:44 pm »
It can be easily adjusted by tweaking Distribution > Density values. As mentioned in our online documentation, it "... lets the user choose the scale of the distribution map in the scene. The map is applied in a manner similar to the way texture maps are applied in Max. The image is scaled according to the defined size, and tiled in all directions."
Crayox
« Reply #2 on: May 24, 2024, 01:26:07 pm »
Always thought that was only the density of the objects, now I see the behavior. Thanks :)
