Author Topic: Forest LOD for animation issues  (Read 3158 times)
iCreateLtd
« on: January 03, 2019, 04:19:59 pm »
Hi there,
I have recently started using LOD's for trees in forest pack. I am using Min Screen Size mode, and using a Corona camera (no target). In the viewport, as I get closer to trees I can clearly see them switching LODs (I've added  a green material for High poly trees and a red material for the low poly trees, for test purposes only).
However, when I render the frame ranges, the LODs don't swap out, the low res trees remain even when the camera is up close.
Any help would be greatly appreciated,
Many thanks
Sean
Re: Forest LOD for animation issues
« Reply #1 on: January 04, 2019, 11:39:43 am »
I could not replicate any misbehaving objects.
We could only help You if You could share Your scene.
iCreateLtd
« Reply #2 on: January 04, 2019, 04:30:39 pm »
Thank you very much for your reply.
I have attached the 3Ds max scene. As I mentioned, when using the camera in the viewport, the trees switch from red to green (low to high) as you get closer. However, when I render the frames, they remain red. I hope you can help me out, and thanks again in advance.
Sean
« Reply #3 on: January 04, 2019, 04:59:28 pm »
I attach You modified scene.
I used LOD Max distance mode.
iCreateLtd
« Reply #4 on: January 04, 2019, 05:38:42 pm »
Thank you very much for your help.
I can see it works perfectly. I'll compare settings to see exactly what I was doing wrong.
Take care
