Author Topic: Scatter a X amount of object on a spline  (Read 11334 times)
djibvongenf
« on: June 22, 2024, 06:58:31 pm »
Hi All,
I can't figured out how to scatter, let's say, 22 objects on a circle. I can't find a way, or easier to say see, except to give them a fixed distance in between.
Anyone has a clue about this?
thank you
Re: Scatter a X amount of object on a spline
« Reply #1 on: June 24, 2024, 08:43:00 am »
The Path Distribution Mode works in either Spacing mode (which requires adjusting the value accordingly) or In Vertex Positions mode (where you may need to add the corresponding number of vertices). For this type of task, the RailClone plug-in is more suitable. Within the L1S Generator, under Properties > Rules > Evenly, you can set the mode to Count.
RealViz
    • RealViz
« Reply #2 on: June 24, 2024, 04:36:24 pm »
Or you can use "Normalize Spline" and specify the number of vertices. Then enter "On Vertex position" in FP.
