Author Topic: Diversity by Color ID not working  (Read 3841 times)
scott
« on: October 06, 2016, 07:32:08 pm »
Inspired by the latest tutorial, I set out to create my own bio wall using color ID for diversity.
It hasn't worked well.
First, I created the wall seen in the image and it wasn't working when I went to set the color ID bitmap.  When I went into another scene and re-opened this one, it was suddenly working.  Weird.
However, the wall on the right is a new attempt to create a patterned biowall.  All I get is this sort of random splotchy mess.  In other words, I have no idea why the first biowall is now working, but the 2nd one isn't.
Next, I have a flat biobed.  This isn't working at all - only 1 color of the ID is showing up.  It's incredibly infuriating, lol.
Okay, what am I doing wrong? ???  Am I forgetting some vital step that I accidently did the first time out?
scott
Re: Diversity by Color ID not working
« Reply #1 on: October 06, 2016, 08:18:39 pm »
Basically some further tests show that when I create a simple rectangular plane it MIGHT work.  Any sort of spline and it never works...
« Reply #2 on: October 07, 2016, 09:23:51 am »
Please note Diversity map requires UV coordinates to work, which are taken from the underlying surface.
So you must assign at least a Surface in Forest. There are not problems to use Spline areas as well, but always combined with a Surface.
To avoid that Forest scatters items along all the surface, just turn off "Surface Area" in the Areas rollup.
When there is not a Surface, Forest generates its own (fictional) UV coordinates from the Distribution map settings. These are used for other Forest features, but generate wrong results with Diversity maps.
