Author Topic: Diversity issue  (Read 2661 times)
in3des
Diversity issue
« on: October 12, 2020, 11:00:48 am »
trying to scatter trees using color mask - looks like it doesn't work... ((
Please help if I'm doing some wrong settings.
Thx
Re: Diversity issue
« Reply #1 on: October 12, 2020, 01:37:51 pm »
What You are using now is trying to match color ID on Your map.
It tries its best to find colors on the surface, You are using only one color- RED. It will always find that red color is closest to anything else on the map.
What You probably want is masking. So You need to prepare map as a grayscale mask and use as distribution map.
Hope this helps.
in3des
Re: Diversity issue
« Reply #2 on: October 12, 2020, 02:20:01 pm »
Ok, thanks!
I thought it works in different way :)
finally splitted RGB channels as 3 separate maps
