Forest Pack => Forest Pro (*) => Topic started by: in3des on October 12, 2020, 11:00:48 am
trying to scatter trees using color mask - looks like it doesn't work... ((
Please help if I'm doing some wrong settings.
Thx
What You are using now is trying to match color ID on Your map.
It tries its best to find colors on the surface, You are using only one color- RED. It will always find that red color is closest to anything else on the map.
What You probably want is masking. So You need to prepare map as a grayscale mask and use as distribution map.
(https://i.imgur.com/m5IZOAy.png)
Hope this helps.
Ok, thanks!
I thought it works in different way :)
finally splitted RGB channels as 3 separate maps
