Author Topic: Max 2025 install disappeared.  (Read 15556 times)
Geoff K
« on: April 09, 2025, 04:32:59 pm »
I'm not using Max 2026 yet, but I do have it installed and I just installed the latest versions of ForestPack and RailClone for it. Now iTooSoft products are no longer are available in Max 2025 (but they are in 2026). I uninstalled them and reinstalled the previous versions but they they still aren't showing up.
So I tried re-installing the new versions, this time making sure I installed it for both Max versions. But only Max 2026 is checkable (see attached screenshot). And when I do the same with the previous versions, I cannot specify any Max version at all.
« Last Edit: April 09, 2025, 04:36:20 pm by Geoff K »
Re: Max 2025 install disappeared.
« Reply #1 on: April 10, 2025, 09:13:01 am »
Hi Geoffrey,
I'm sorry to hear you're experiencing trouble with it. We've run additional tests on multiple configurations here, and everything seems to be working correctly. Could you please double-check your system registry to ensure that the following key corresponding to 3ds Max 2025 is present?
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\3dsMax\27.0
Thanks in advance for any further comments you can share about this issue with us or our user community, in case others run into similar troubles.
Geoff K
« Reply #2 on: April 10, 2025, 02:18:21 pm »
It looks like somehow 27.0 got removed (25.0, 26.0, and 28.0 are there though). I just tried to re-install Max 2025, but it would not proceed, saying that it is already installed. Do you know how I might be able to get it back? A week or so ago I removed Max 2024 and other associated things using a program called BC Uninstaller. I wonder if that had something to do with it.
« Last Edit: April 10, 2025, 02:20:12 pm by Geoff K »
Geoff K
« Reply #3 on: April 10, 2025, 08:40:18 pm »
Wow! Looks like ChatGPT knew how to modify the registry and fix the problem. I'm all good now. :)
