Author Topic: Does ForestMaterial support in V-Ray?  (Read 4937 times)
SL7359
    • OakCorp Home
« on: May 13, 2015, 09:21:23 am »
There is a question of "Random Tint of ForestMaterial does not work by V-Ray?" frequently from our customer.
Of course, it explains "using ForestColorMap."
But is there any plan to support ForestMaterial(Random Tint) by V-Ray?
Thanx
OakCorp
Yuji Yamauchi
OakCorp Japan
Yuji Yamauchi
3dsMax[Latest]/Geforce GTX 1080/Windows10 Pro/ V-Ray for Max[Latest]/GrowFX[Latest]
Re: Does ForestMaterial support in V-Ray?
« Reply #1 on: May 13, 2015, 10:00:13 am »
All features are supported in V-Ray, including Forest Color.
Are you sure they mean V-Ray and not V-Ray RT ?  With RT is a different issue, it doesn't support Forest Color and other advances features. You can find the technical details here.
SL7359
    • OakCorp Home
« Reply #2 on: May 13, 2015, 11:52:56 am »
It is not RT.
V-Ray is supporting Random Tint of ForestMaterial? (Forest Color is not used)
It is not supported in my confirming. (V-Ray 3.0 + 3dsMax 2015)
« Last Edit: May 13, 2015, 11:56:21 am by SL7359 »
OakCorp Japan
Yuji Yamauchi
« Reply #3 on: May 13, 2015, 08:49:16 pm »
Yes, V-Ray is supported for Random Tint, although this feature requires Forest Material or Forest Color.
Usually Forest Material is used for billboards (applied as a material), and Forest Color for 3D objects (applied as a texture map).
If you send us a sample scene, we would check what is the problem exactly.
SL7359
    • OakCorp Home
« Reply #4 on: May 14, 2015, 08:04:05 am »
At V-Ray, random tint does not work by billboards.  :-\
(of course  does not work by 3d object )
« Last Edit: May 14, 2015, 08:05:40 am by SL7359 »
OakCorp Japan
Yuji Yamauchi
« Reply #5 on: May 14, 2015, 10:47:04 am »
Thanks for the scene, now i see the problem. This should work, but it does not in V-Ray 3.0 and above (2.0 works fine).
We have sent a request to ChaosGroup team. From our side everything seems correct, but probably we're missing something.
I apologize for any inconvenience.
« Reply #6 on: May 15, 2015, 11:14:19 am »
Hi, we finally found and fixed this bug. The fix will be included in the next Forest update.
SL7359
    • OakCorp Home
« Reply #7 on: May 18, 2015, 12:20:29 pm »
Thank you for the support.  :)
OakCorp Japan
Yuji Yamauchi
