Toggle navigation
Login
Register
Forest Pack
Forest Pro (*)
UV Mode on Surface, cannot use geometry to exclude areas
« previous
next »
Print
Pages: [
1
Author
Topic: UV Mode on Surface, cannot use geometry to exclude areas (Read 3320 times)
grue
Full Member
on:
June 16, 2021, 04:10:38 pm »
i never noticed this before, but if i use UV Mode, I cannot then add a 3d geometry object to the Area in order to exclude scattering where that 3d geometry object is.
is there another way to use a piece of geometry to exclude?
thanks
Logged
Hero Member
Re: UV Mode on Surface, cannot use geometry to exclude areas
Reply #1 on:
June 17, 2021, 09:40:06 am »
UV mode does not support geometry exclude. You can have some control when using distance map. But it does not work fully as expected.
We will check this, but don't know if this can be fixed.
Anyway attached a sample scene, maybe it will give You some ideas.
Logged
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
