Author Topic: don't want it to change automatically( from random to model)  (Read 6794 times)
roysgi10
« on: March 14, 2014, 09:54:41 am »
Hi.
Look at the attachment and see what i meen.
Re: don't want it to change automatically( from random to model)
« Reply #1 on: March 14, 2014, 11:42:28 am »
Are you unable to add any objects in random mode or it changes after deselecting this Forest object or creating new Forest / cloning it? Which version of Forest Pack / 3D Max are you using?
As it´s an adjustment for adding new object and not a property of Forest object, this option is not saved in preset for Forest object so the behaviour is "normal".
Kind regards,
roysgi10
« Reply #2 on: March 14, 2014, 09:10:56 pm »
it changes  automatically to model after deselecting this Forest object
roysgi10
« Reply #3 on: March 14, 2014, 09:13:01 pm »
i use the last beta FP 4.2.0B  but its also happen with the previos versions
« Reply #4 on: March 15, 2014, 09:40:19 am »
As Michal noted, this behaviour is normal. This is not a parameter of the Forest object, but a selector of "Add Items". It resets when the Forest interface closes.
SM3464
« Reply #5 on: March 17, 2014, 06:53:16 pm »
Same thing happened to me, I'ts a bit annoying when you are adding items manually, maybe the "random" option should be the default one?
« Reply #6 on: March 18, 2014, 08:43:11 am »
You are right. It has more sense to set random as default. We'll change it.
