Author Topic: grass area bug  (Read 6569 times)
CO2263
grass area bug
« on: October 28, 2013, 05:04:20 pm »
trying to make grass with nice edges but have some bug
invert spline thing seems not working properly
pls see screenshot
download link for the clean scene
https://mega.co.nz/#!6Rg2GRKJ!XaGQo2LRG-ALubpjmNWMjT0y0noR1GK1MZ7GtcI8_uo
CO2263
Re: grass area bug
« Reply #1 on: October 28, 2013, 05:09:55 pm »
pls advise how to fix the issue
Re: grass area bug
« Reply #2 on: October 28, 2013, 08:14:23 pm »
The problem is caused by the inner region marked in the picture. It seems the algorithm that computes the inverted falloff, doesn't work well with excluding regions. We'll check it.
As workaround, delete that region in the @cur_grass_border spline. If you need a nice edge in that area, create a separated Forest object with their own spline.
CO2263
Re: grass area bug
« Reply #3 on: October 29, 2013, 07:51:54 am »
thx!
that area is pool
actually i don't need nice edge exctly in that spot, will try to delete inside spline and add exclude area around
JQ1899
Re: grass area bug
« Reply #4 on: March 13, 2014, 09:44:21 pm »
Just curious to know if there has been any movement on this. We are running Forest Pro 4.1.5 and I just ran into a similar issue with the inverted falloff.
Thank you
Matt
Re: grass area bug
« Reply #5 on: March 14, 2014, 09:26:50 am »
Yes, this bug is fixed in Forest Pro 4.2.0 beta:
- Inverted fallof curves can be used at same time with including and excluding areas.
JQ1899
Re: grass area bug
« Reply #6 on: March 14, 2014, 08:33:17 pm »
Cool beans! Thanks for the update.
