Author Topic: lookat + transform  (Read 2723 times)
EI3626
lookat + transform
« on: March 02, 2022, 11:59:53 pm »
I have a forest of 3d people that I'm trying to all face an object. When I apply the lookat option, they all face the object, but rotated 90 degrees. The transform option doesn't seem to work. Does anyone have any suggestions? I don't want to rotate the individual objects because they are all being used in several other forests in the same scene.
Thanks!
Re: lookat + transform
« Reply #1 on: March 03, 2022, 02:54:13 pm »
The lookat feature does override the random transforms as you've pointed out, however, there is a solution using Forest Effects. Just import the effect attached to this post and you can randomise or control the randomisation as well as using the lookat target.
I hope that helps,
EI3626
« Reply #2 on: March 03, 2022, 03:09:09 pm »
perfect. thank you for the help!
