Author Topic: Dreaded BOXES  (Read 30764 times)
Bobby Parker
Dreaded BOXES
« on: June 12, 2025, 01:54:29 am »
The dreaded boxes, which I haven't seen in years. MAX 2026 and the latest V-Ray.
Re: Dreaded BOXES
« Reply #1 on: June 12, 2025, 08:53:14 am »
Hi Bobby,
I recommend reviewing our FAQ post on Distributed Rendering issues (also applicable to network rendering with Backburner) to help identify the cause of the problem in your case. Additionally, please check all references used by Forest Pack with the Asset Tracker and ensure they are resolved to absolute UNC paths.
If the issue persists, would you mind enabling logging and sending us the log file? To do this, set General > Log Level to Debug in any FP object in your scene before sending it to the renderer. The log file can be found at:
C:\Users\<username>\AppData\Local\Autodesk\3dsmax\<3dsmax version>\ENU\Network\Max.log
Ideally, please send us two logs — one from a node that renders the distribution correctly, and one from a problematic node — so we can compare the data.
Thanks in advance.
Bobby Parker
Re: Dreaded BOXES
« Reply #2 on: June 12, 2025, 06:11:40 pm »
It is a denoiser issue
Bobby Parker
Re: Dreaded BOXES
« Reply #3 on: June 16, 2025, 08:17:00 pm »
I do not use DR
