Author Topic: Error Loading Library  (Read 7039 times)
NI1952
« on: July 01, 2021, 03:34:27 pm »
Hey guys,
I get following error when i try to load most of the presets.I've checked "3d_corona.mat" file exist.
I've googled but couldn't find solution.
Any idea how to fix it?
3ds Max 2019/Corona Render/Forest Pro 7.1.1
Re: Error Loading Library
« Reply #1 on: July 01, 2021, 04:53:04 pm »
Does that file (3d_corona.mat) exist on the corresponding location %localappdata%\Itoo Software\Forest Pack Pro\matlib ?
I would suggest reinstall the problematic packages in the following way from the Update Manager:
If you cannot see installed packages, Go to the View menu and select Installed Packages.
Click on the (i) icon for the package you'd like to remove
From the Details Dialog, click Uninstall.
After it is uninstalled, hit the Install button on the bottom of the Update Manager.
Hope that helps.
NI1952
« Reply #2 on: July 08, 2021, 08:12:45 am »
Hi Rokas,
Thanks for reply.Yes the .mat file is in correct location.
I've tried to uninstall and reinstall problematic presets but the error continues. :(
If i click ok the preset loads but with standard materials.
« Reply #3 on: July 08, 2021, 08:39:30 am »
From this screenshot we see that You seem to have added forest library twice. Seems this one You are using is badly added. Please remove it.
Please try this
Go to Library browser options and make sure only this path is present:
Well mine has "rokas" in it, Yours will have different name.
NI1952
« Reply #4 on: July 08, 2021, 11:41:59 am »
Ah yes that solves the problem :)
I've removed the duplicate library and correct the path of "Forest Pack Pro Library" now it's working fine.
Thanks for your help.I really appreciate.
