Author Topic: objects with vray displacment  (Read 5346 times)
lukx
    • lukxCGI
« on: July 17, 2016, 04:15:21 pm »
Im trying to use forrestpack with few objects with vray displacement on them but displacement doesn't show when rendered. So I applied vray disp on top of forrest pack and then forest pack disappeared in viewport but displacement rendered :). Is there any workaround so is shows in viewport?
Re: objects with vray displacment
« Reply #1 on: July 17, 2016, 05:01:23 pm »
You can make modifier off in viewport
But for me it doesn`t work to add vraydisp modifier on top on forestpack object.
lukx
    • lukxCGI
« Reply #2 on: July 17, 2016, 07:36:22 pm »
thanks :) but overall the displacement doesn't work when only on object used? what if I want to have different objects with different vray displacement maps ?
« Reply #3 on: July 18, 2016, 11:36:20 am »
Unfortunately that's a limitation of the render engine: VRay's Displacement cannot be applied to instances or proxies (by using VRayDisplacementMod / Displace map within the VRayMtl applied on distributed items). Instead you can apply a standard 3ds max's "Displace" modifier to the source object. Just take in account that all scattered items will have the same displacement, since they are instances of an unique geometry.
