Author Topic: FP8 - crash when moving ForestSet into a layer referenced by itself  (Read 3167 times)
RM2551
I was just playing around with FP8 and as a developer the new From Layers option of Forest Set makes me a bit nervous :) Just looks like this could potentially create all kinds of dependency issues in combination with other features and plugins. Anyway, found this crash during my tests:
Create a Layer "Test" with some simple objects
Created a Forest Set and added the layername "Test" to it.
Made a Forest object using the new Forest Set as geometry source.
In layer manager dragged Forest Set into layer Test. (makes no sense, this was a test)
Result: Lots of error messages popping up and 3ds max crashing (Lots of MAXScript call stack overflow errors until Maximum Nester Error Dialog Depth Reached).
Regards,
Daniel Schmidt
Re: FP8 - crash when moving ForestSet into a layer referenced by itself
« Reply #1 on: November 07, 2022, 11:02:17 am »
Hi Daniel,
Thanks for reporting this issue.
Usually Max takes cares of circular references when picking objects, but for layers we should it manually. We'll take a look to it.
