Author Topic: water drops  (Read 3635 times)
Pierre
    • Studiosezz
water drops
« on: March 24, 2015, 11:04:53 am »
hello,
I try to use forest to paint water drops on a bottle but I can not do what I want.
I tryed first with XY mode but it's limited to one plane. I can detach part of the face and create multiple forest but it's a bit complicated.
I tryed then with UV mode and a gradient map to place the density of water droplets but forest doesn't seem to understand the gradient (see attachment).
Am I doing something wrong ?
Thank you for your help
Pierre
Studiosezz PARIS
www.studiosezz.com
Re: water drops
« Reply #1 on: March 24, 2015, 01:06:12 pm »
Hi Pierre,
For purposes like that, would be the UV mode the right choice. Under Surface - Altitude Range you can control Top & Bottom limits and also Density Falloff & Scale Falloff. This way you can easily define desired effect.
Hope that helps.
Kind regards,
Pierre
    • Studiosezz
Re: water drops
« Reply #2 on: March 24, 2015, 02:50:53 pm »
Hello Michal
thank you for your answer, I didn't thought of this option. I will try
Pierre
Studiosezz PARIS
www.studiosezz.com
