Author Topic: Edge mode dosen't work  (Read 4884 times)
Mike123
« on: May 25, 2022, 12:25:31 pm »
Today I try the boundary checking with edge option - why it dosen't work?Seems I am right.
I attached my 3ds max file here.
Thx!
Re: Edge mode dosen't work
« Reply #1 on: May 25, 2022, 12:30:56 pm »
Thanks for the file. In my test here it appears to be working as expected. Edge mode doesn't slice the model, but looks at each individual element to check if its lowest vertex is inside the area, if it is then the element is retained, if not it is removed. This allows for a more natural spillover at the edges rather than a hard cut.
I hope that makes sense,
Mike123
« Reply #2 on: May 25, 2022, 12:41:17 pm »
Hi Paul,
Thx for your reply.
So that is to say - if my gemometry is a group of grass ( such as circle group), it can't cut the edge perfrectly as well right ?
even using edge mode.
« Reply #3 on: May 25, 2022, 12:48:26 pm »
In the case of using a group you wouldn't need to use edge mode because each object in the group would be evaluated individually. Be aware though that in the latest Forest Pack you would need to disable Keep Group Hierarchy in the Items rollout for that to work.
If you enabled Edge mode then each item within the group could be clipped at per-element level as well.
I hope that helps,
Mike123
« Reply #4 on: May 25, 2022, 12:50:05 pm »
Thx Paul,let me have a try!
« Reply #5 on: May 25, 2022, 12:52:02 pm »
You might find when using groups that Size mode gives you something closer to the results that you want.
