Author Topic: Fill Cluster holes  (Read 4728 times)
plan b Agentur
Fill Cluster holes
« on: September 29, 2015, 04:26:38 pm »
Hello Everyone,
I'm using the Daisy 01 large preset (With the probability of the daisies changed to 10%) on a large surface. The Problem is, I'm having holes in my Forest. I narrowed it down, that it has to do with the Cluster option. If I use random scatter mode instead of cluster, the holes vanish. In Cluster mode however it looks like the attached file. Lowering the Units in the the Distirbution Map Density doesn't really affect these holes. Nor does changing the values much, unless I reduce the cluster size. But I would have to reduce it to a value less then 1m, which doesn't look good. If I increase the Cluster size to let's say 10m, the holes become bigger as well.
Has anyone an idea how I could fix those holes?
Re: Fill Cluster holes
« Reply #1 on: September 29, 2015, 05:03:36 pm »
Looks like, you've Disabled or changed the Scale value for some of used items. Could be that the case? Changing just the Probability value shouldn't affect the preset in this way.
plan b Agentur
« Reply #2 on: September 29, 2015, 05:36:14 pm »
Well, stupid me. One of the daisy objects was disabled. Now the holes are filled with different daisies ;)
