Author Topic: Scattering Objects between 2 surfaces?  (Read 2982 times)
SF1329
« on: June 01, 2017, 12:59:09 pm »
Hi guys,
I am trying to figure out a way of using a surface as height limit for a forest pack object.
As you can see from the attachment, I  have got a base surface (green one) and a simple geometry (a box) , now I want these boxes to have all different heights, controlled by Surface B (the red one).
I could use a Zmap, but unfortunately the B surface is not flat either, and has a lot of little variation and it needs to be 100% precise.
Is there a way of doing it?
Thanks!
SF1329
Re: Scattering Objects between 2 surfaces?
« Reply #1 on: June 01, 2017, 01:47:00 pm »
Just tried with the Zdept map, and it won t work as both surfaces are not flat.
« Reply #2 on: June 01, 2017, 01:57:32 pm »
For this kind of tasks will be better to use the RailClone plug-in. A recommendable set-up would be to use two Generators - to build "bottom" & "top" parts separately. This way you can use two surfaces or combine it with splines (I've used splines for the bottom part). Attaching a sample scene. Hope you'll find it useful.
