Author Topic: thing to select used geometry, proxies)...  (Read 6731 times)
lukx
    • lukxCGI
« on: August 25, 2017, 08:14:09 am »
Does something like this exist or can be added to Forest Pack (script or something) that I could select all geometry and proxies that has been used as forest pack objects in scene?
Re: thing to select used geometry, proxies)...
« Reply #1 on: August 25, 2017, 10:15:57 am »
You can use the Max selector with "Select Influences" enabled, to achieve a similar result.
Selecting one or more FP objects with this option enabled, will select also all dependent objects (geometry, surfaces, areas, etc).
Same option can be used with "Merge", to import FP objects into the scene.
lukx
    • lukxCGI
« Reply #2 on: August 25, 2017, 12:17:45 pm »
Fantastic !!! Thank you Carlos !
