Author Topic: Error After Render  (Read 3160 times)
Bobby Parker
Error After Render
« on: June 10, 2016, 03:39:04 am »
Okay, I am a fanboy, but why get the error when the render is complete? You know, the view stats error, which means your Forest object didn't render. Can't it tell you this before your rendering is completed. I tend to hit render, walk away and come back later to see a completed render, just to see the error.
Re: Error After Render
« Reply #1 on: June 10, 2016, 09:31:46 am »
I will check it, but not sure if can be done. After rendering is a safe point to show the error message, but i don't know what side effects would be to show it at other render stages.
Futhermore, each render engine supported by Forest uses a slightly different workflow. So, it may work with one and generate a crash with other... it's a tricky issue.
Bobby Parker
« Reply #2 on: June 10, 2016, 04:25:56 pm »
I see. Thanks for the reply.
