Author Topic: Forrest Pack Reference  (Read 26561 times)
JG_archviz
    • JG
« on: July 15, 2025, 11:51:35 am »
I've trouble to understand why its not working - rendering.
One ForrestPack Object is distributing Planters - which each has randomly placed Mesh-faces with ID10 as a "reference" for distributing vegetations.
The other Forrestpack Object is having various Plant Models as geometry and are distributed by "Reference" Mode  - using "Mesh Faces" - items by Face 1 and because the other forrestobject reordered the various materials... ID 10 became ID 8 ... so its ID 8.
I do see the Plants have been correctly distributed with point-clouds... its also not too much geometry produced. i increased max items and max faces...
But it doesnt show when rendering.
It does show if i convert the Forrest-Objects with all the vegetations into a mesh and collaps it down to a mesh. then its rendering as it should be .
Any Idea why it doesn't work as i thought it should?
Max 2025 and Forrestpack 9.2.4 and Corona 13
JG_archviz
    • JG
Re: Forrest Pack Reference
« Reply #1 on: July 15, 2025, 11:55:11 am »
i guess i found out myself... when finding a answer to using rail-clone and "instancing off" ...
So i set the FP_Planter object render mode to mesh not automatic. that worked then.
« Reply #2 on: July 15, 2025, 12:04:09 pm »
Exactly, changing the Render Mode of the Forest object that is used as the reference for the other one from Automatic to Meshes (under the Display rollout) should resolve the issue.
