Author Topic: Library Scales  (Read 2791 times)
Simon Tether
    • Stratus Environmental Limited
Library Scales
« on: November 16, 2015, 11:56:19 am »
Recently, when I use a standard library preset I get a dialog warning me a XREF scale mismatch.
XREF is Centimetres and I work in metres, is there a way to set Forest to use metres as default ?
I'm sure this is only a recent thing as I dont remember it happening before ?
Re: Library Scales
« Reply #1 on: November 16, 2015, 12:06:51 pm »
This warning dialog was introduced in Max 2016. We have contacted with Autodesk in case there is some way to avoid it, but unfortunately not.
Problem is not Forest because it uses scene's units, but the library max files. They were created in centimeters, so there is not an easy way to modify them.
