Author Topic: forest sets in layer mode, icon text  (Read 35858 times)
ritoo
« on: August 30, 2025, 10:52:36 am »
1. When a forest object in reference mode (which uses a forest sets in layer mode) being copy-pasted to another file, the layers (which were mentioned in the forest set) are not transferred. Would be possible make it happen?
2. currently FP icon texts are too small, please enlarge maybe 30-50%
« Last Edit: August 31, 2025, 02:52:42 pm by ritoo »
Re: forest sets in layer mode, icon text
« Reply #1 on: September 01, 2025, 10:05:30 am »
(1) The ForestSet > From Layer feature doesn’t create a live link to the source objects, so there’s no dependency between them and the Forest object itself. That said, you might find the following property helpful, as it lists the names of these layers:
$.layernames
Using Maxscript, you can use this property to quickly select all objects from those layers and export them. I hope this helps.
(2) We’ll take this into consideration for future updates. However, since these icons were changed fairly recently, we’d prefer not to update them too frequently. Thanks for your understanding.
