Author Topic: ForestColor on xRefObject  (Read 4517 times)
DF2688
« on: June 27, 2018, 08:56:15 am »
Does anyone know the way or thread how to work ForestColor on xRefObject ?
It works on source scene or xRefScene, but doesn't work on xRefObject.
I can't find topic about it.
Tested enviroment is below.
3dsMax 2017 Update2
ForestPack Pro 5.4.0
Vray 3.4.02 and 3.6.04
Re: ForestColor on xRefObject
« Reply #1 on: June 27, 2018, 10:58:49 am »
Can You please attach a non working scene?
It should work with no special options.
« Last Edit: June 27, 2018, 11:01:28 am by Rokas »
DF2688
« Reply #2 on: June 27, 2018, 11:48:59 am »
>Rokas
Thanks for your reply.
It seems that xRefObject was converted to be merged because the source path has changed.
I attach both "SourceScene.max" and "LightScene.max", so please insert the "SourceScene.max" by xRefobject to the "LightScene.max" and render it.
« Last Edit: June 27, 2018, 11:54:27 am by DF2688 »
« Reply #3 on: June 27, 2018, 01:35:00 pm »
You want to xref ForestPack object as it is in SourceScene.max file?
I get Max Crash error by merging with Your instructions.
DF2688
« Reply #4 on: June 28, 2018, 03:51:09 am »
Here is my process video what i captured 3dsmax UI.
https://drive.google.com/open?id=1jb6gwShgeBEa73PlXElB3q9RRClWrnsm
I have no idea why max crash in your PC...
« Reply #5 on: June 28, 2018, 11:20:39 am »
Big thanks for reporting it and all info provided. We are investing possible ways of material handling when the FP object is being linked as an XRefObject (the most usual set-up is using Custom Objects loaded as XRefObjects).
Using the XRefScene feature (working in a slightly different way) for this kind of purposes (when the FP object needs to be referenced) would be the currently recommendable way.
DF2688
« Reply #6 on: June 29, 2018, 05:13:33 am »
I'm looking forward to improve this issue.
