Forest Pack => Forest Pro (*) => Topic started by: ER1951 on June 19, 2018, 09:09:02 am
Hi~
I am using 3ds Max 2018, forest pack pro 6.1 and V-Ray Next(trial) version.
After updating, I get an error message in one kind of preset to find out the problem.
I uninstalled and reinstalled the same thing.
I want you to know how to do it.
Hello
Thanks for reporting this.
Please try manually select vray in the renderer list:
(https://i.imgur.com/h8mEIAj.png)
Thank you for quick response.
The problem did not occur when you did it manually.
But the other user is automatically, is there a problem with the script?
Thank you.
can You please paste this line in maxscript listener and write back what You get from it:
renderers.current
(https://i.imgur.com/FbxW6RH.jpg)
Thank you.
However, several more errors occurred.
If I switch to another renderer (ex : corona render), I don't know how to fix it because the same error occurs.
Will everything have to be newly installed? Only (Vertical) sections occur for this preset.
I'm bad English. :'(
Thank You.
We found a bug in our xml.
Please copy attached file to this folder (with overwriting):
%localappdata%\Itoo Software\Forest Pack Pro\lib\Presets\Vertical
This update will be live for everybody soon too.
Thanks you again.
When I tried to use the modified file, I found that it is not automatic yet and works only manually.
And some of the other presets had problems. :'(
I will wait for the soon to be fully operational. ;)
Thank You!
Best regards!
I am sorry for confusion. Automatic selector is different issue. It wont be fixed soon.
We fixed "Grape Ivy | XY " what other presets You find misbehaving?
Okay. Please fix the automatic selector problem later.
Other setup issues are the same, with some automatic selector problems in PresetssStones. Of course, there was no problem when I did it manually.
Perhaps there is more, but here's what I've checked for now.
Thank you, anyway.
ps : Overall tested results indicate that there is a Automatic selector Issue.
