Author Topic: Mental Ray Slow Render  (Read 49977 times)
Biomanniax
« on: June 26, 2007, 11:44:34 am »
Hi folks, i just installed Forest Pro and im experiencing veeeeeery slow render times using Mental Ray in Max9 (compared to normal billboard trees with the same maps). Is there anything i can do about that ? Is the plugin in some way optimised for MR or not ??
Re: Mental Ray Slow Render
« Reply #1 on: June 26, 2007, 08:11:00 pm »
We know that Mental Ray is very slow using opacity maps (because the way that a raytrace works), but i have not seen differences using Forest objects or billboards.
I just done a test scene, first rendering a Forest object and converting it to an editable mesh, but the render time was identical. If you have other test scene which show different results, please send it to us for checking.
Unfortunately, the documentation of Mental Ray for developers is very sparse, so we have not much information about the MR engine for optimizing it with Forest and opacity maps.
