Forest Pack => Forest Pro (*) => Topic started by: TB4709 on August 23, 2024, 07:02:01 pm
we are having an issue when we try to use the Export API with Forestpack like it is said in this documentation. This is what we are using
Forest_pro.ForestPack.exportData c:\tmp\test.xml "index geomID geomName finalTM"
it doesn't generate any error, and only returns "2". Note that it works when using the button of the interface.
Here is a test scene so you can see the issue.
Thank you for your help.
I'm sorry to hear you're experiencing issues with it. Which version of ForestPack you're using? While there was a known issue in FP8, it was resolved in FP9 and the following command in the latest beta version (FP 9.0.8b) should work just fine:
Forest_pro.ForestPack.exportData "c:\\tmp\\test.xml" "index geomID geomName finalTM"
I hope this helps.
