Author Topic: FP area excluded by spline doesn't work correct.  (Read 34435 times)
ZO6039
« on: August 22, 2024, 08:25:03 pm »
FP area excluded by spline doesn't work correct for multiline splines. As you can see on image there are excluded areas of FP by horizontal lines of spline with thickness. I expect do not see FP objects between two top horizontal lines of spline because both of them have thickness, which should remove FP objects between them. But this is not true and looks like a bug.
« Last Edit: August 22, 2024, 08:29:33 pm by ZO6039 »
Re: FP area excluded by spline doesn't work correct.
« Reply #1 on: August 23, 2024, 10:15:43 am »
Thanks so much for reporting this, I can reproduce the issue here. We will investigate and see if it can be fixed.
In the meantime, you can work around that problem by detaching one of the two overlapping splines and adding it as a separate area.
I hope that help,
ZO6039
« Reply #2 on: August 23, 2024, 07:41:56 pm »
My problem is that I have a rail road system created by splines over terrain. Each road has two lines of splines. And I use the same splines as exclude area for FP objects. And because of the current state how exclusion works for two closest lines I have trees popping out between rail road rails.
« Last Edit: August 23, 2024, 07:43:28 pm by ZO6039 »
