Forest Pack => Forest Pro (*) => Topic started by: MN1161 on July 19, 2017, 03:30:24 pm
Good afternoon,
I have parsed the forum and seen a few issues that relate but no solution that has worked - nevertheless, it seems to be a common issue.
Essentially I have two Evermotion packs, I have downloaded your plugin for the Evermotion libraries. When I click on any given model from a library it asks me to 'select installation path'. I locate the library and no matter how I do it (selecting root or individual folders) I get the same message : 'the selected folder does not contain Evermotion Plants library'.
Any help is much appreciated.
Sorry to hear you're facing those troubles. I would suggest you to check this post (https://forum.itoosoft.com/index.php?topic=4029.msg15739#msg15739), where you can find the evermotionplants.ms file, which should help (I guess you didn't unpacked the mental ray models - the updated version only verify the V-Ray folder).
Best regadrs,
