Author Topic: Exclude Object Resolution - Strange results  (Read 6410 times)
Michael Betke
« on: March 22, 2019, 06:42:35 pm »
I followed your FPP/RC tutorial to do a pavement with grass inside.
The problem I have is the resolution I can set for the object exclusion. With 8k res I get nice grass inside the holes on the left but nothing on the left.
To show the problem I also made a screenshot with 256px resolution. Both are messed up.
Using last FPP version with Octane Render.
Michael Betke
Re: Exclude Object Resolution - Strange results
« Reply #1 on: March 22, 2019, 06:43:01 pm »
Other image.
« Reply #2 on: March 26, 2019, 11:33:44 am »
If possible, please send us your scene to have a look at it here. Ideally, would you mind to try to reproduce the problem with a minimal scene and send us such a scene? Thanks in advance.
Michael Betke
« Reply #3 on: March 26, 2019, 02:39:29 pm »
I've sent you a file via mail to helpdesk.
Ricousto
« Reply #4 on: February 07, 2024, 06:09:09 pm »
I have the same problem in the same situation (pavement + grass)
did you get a reply to this problem?
Michael Betke
« Reply #5 on: February 08, 2024, 08:45:12 am »
I never solved this. It's happening also with latest version.
« Reply #6 on: February 08, 2024, 09:51:01 am »
I'm sorry to hear that you're facing problems with it. It should work just fine in the latest version. Since Forest Pack 8.2.2, the following patch has been applied: "Fixed artifacts when using high-resolution values (above 4096) in Object Areas."
Can you please send us the problematic scene? Ideally, if you'll be able to reproduce it on a minimal scene, which you can send us, that would be great. Thanks in advance.
