Author Topic: forest colour not working with nested ForestPack objects?  (Read 4290 times)
simmsimaging
« on: June 17, 2013, 11:35:34 am »
I'm working (yet again) on some grass and still trying to get something that really works well for me in hi-res for details and mid-distance. I am working on this with LukX and we are both struggling a bit.
I am using the nested FPP object technique, so I have single grass blades distributed over a 15cm circle. Each has material ID's assigned so that all poly's on a single blade have one ID, and I have randomly assigned 1-10 as the MatID for each blade. I have a material using Forest Colour and 10 maps to randomize the diffuse colour as well as spec and bump. It works great on the single patch of grass.  However, when I use that FPP objects as the geometry for another FPP to scatter over a wide area, then the Forest Colour isn't working properly and the colour cannot be assigned to individual blades properly - it's creating big patches of colour.
Does nesting FPP objects break the Forest Colour mapping somehow?
b
simmsimaging
Re: forest colour not working with nested ForestPack objects?
« Reply #1 on: June 17, 2013, 11:55:30 am »
ah - think it was the item/element needed to be flipped. It was working well with "item" for the single FPP object but switching to "element" works when it's nested. At least I think it worked that way - getting too tired to be sure what I am seeing anymore :)
« Reply #2 on: June 17, 2013, 12:51:20 pm »
That's it. In this case it's necessary to set the tint by element, because each patch of grass (although generated with Forest), is handled as a single mesh object.
