Author Topic: Forest pack - Instance Lights  (Read 1665 times)
iCreateLtd
« on: November 29, 2019, 11:08:20 AM »
Hi.
Can you tell me where this script is?
https://www.youtube.com/watch?v=u2kOk1cTZhM
It's strange for iToo to show something and not make it available..... unless I'm missing something ;)
Re: Forest pack - Instance Lights
« Reply #1 on: November 29, 2019, 11:16:49 AM »
iCreateLtd
« Reply #2 on: November 29, 2019, 11:39:52 AM »
That was quick...
Many thanks
amitgedia
« Reply #3 on: May 20, 2020, 01:10:44 PM »
I am trying to reopen an old thread but had no option
I was trying to distribute the lights along the pavement using the script "FP_lights_instancer.ms", but failed in doing so.
I am using a Vray IES lights so after the instancing and distribution happens all the target merge to one single point which is not correct
I am attaching the 3dsmax file (3dsmax 2017, Vray next 3.2, FPP 6.3.0)
Hope someone helps me asap as i am on a strict deadline
Thanks in advance for anyone who helps
Amit
« Reply #4 on: May 20, 2020, 01:22:42 PM »
Make sure Your lights are not targeted before You instance
amitgedia
« Reply #5 on: May 20, 2020, 02:22:36 PM »
Hi Rokas,
Thanks for the reply, i unticked the target option and it worked but all the lights instanced upside down so i had to rotate them in the right direction
Also i think the limitation of the script is that if you change the distribution distance then the instance light doesn't change we have to redo the distribution all over again
Also is it possible to group the geometry and the light and distribute it because it did not work for me, is it possible via railclone because that also did not work either, might be there is a different method or so.
Thanks again Rokas for the help.
« Reply #6 on: May 20, 2020, 02:48:46 PM »
Sorry. Yes You listed all the limitations. There is no better way to do it, yet.
amitgedia
« Reply #7 on: May 20, 2020, 07:11:16 PM »
Hope to get a script or an effect or might be a RC macro in future to make things easier.
Thanks Rokas once again.
You guys are doing really great and hope all the family members of all the Itoo group are safe and sound.
Take care guys.
