Toggle navigation
Login
Register
Forest Pack
Forest Pro (*)
V-Ray Material Override
« previous
next »
Print
Pages: [
1
Author
Topic: V-Ray Material Override (Read 3467 times)
Bobby Parker
Sr. Member
on:
June 12, 2015, 03:05:19 am »
My grass is making my white soffit green, so I put a V-Ray Override Material with a Vray gray material for the GI over it. I render, the green reflection is still there and when I go back to the material, the override material is gone.
Logged
ITOOSOFT
Hero Member
Re: V-Ray Material Override
Reply #1 on:
June 12, 2015, 10:11:36 am »
As mentioned in our
on-line reference guide
"Since any object in Max can only have one material applied, Forest Pack Pro automatically creates a Multi/Sub object material based on the materials assigned to each individual item in the Geometry List. "
It is not safe to modify directly that "automaterial", because Forest keeps references to its source materials. Instead you should modify the material linked to that item -
Custom Object(s)
Material
. Any changes made this way, will be projected safely to the Forest's "automaterial".
Hope that helps.
Logged
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
