Author Topic: "Select all forest dependences" improvement.  (Read 8919 times)
ritoo
« on: April 16, 2024, 03:09:21 pm »
If given forest in reference mode (with reference object set to Forest set with "from layers" option) I would like this command (see the subject) to select not only the forest set but also all nodes in this layer too.
Possible?
Re: "Select all forest dependences" improvement.
« Reply #1 on: April 17, 2024, 07:53:22 am »
I'm afraid that the current implementation of the "From Layers" feature has several limitations (these objects aren't assigned as references), and as far as I know, there's currently no way to bypass it. Thank you for your understanding.
