Author Topic: Mirrored surfaces problem  (Read 3110 times)
DU856
« on: January 27, 2017, 08:53:56 am »
Hi. After mirroring surfaces with assigned Forest object, those surfaces
are not recognized by Forest objects any more.
Re-assign doesn`t work. No way to make them work again.
After creating brand new surface and assign it to Forest object, it works again.
Jozef
Re: Mirrored surfaces problem
« Reply #1 on: January 27, 2017, 10:12:05 am »
Hi Josef,
It sounds like, the mirrored surface has inverted normals. As mentioned in this "Weird problem with FP - not scattering on poly at all" tightly related post: "... Surface has flipped faces (thought in the view-port it doesn't seem so - please feel free to do some additional testing with the xView - Face Orientation tool or a 2Sided material) ... in similar cases Flip normals > Reset XForm - Reset Selected > Convert to Editable Poly should fix it."
Hope that helps.
Best regadrs,
DU856
« Reply #2 on: January 27, 2017, 10:46:19 am »
Thanks Michal, will try it.
Jozef
