Author Topic: Feature request - unlock XYZ Scale for Geometry - instead of Transform  (Read 2917 times)
Morne
Hi Team
When having multiple objects as geometry, instead of using the transform to unlock the XYZ scale for ALL objects at same time, would be nice to have the current "scale" switch in Gemoetry unlocked to XYZ PER geometry item. That way I can for example stretch 2 or 3 items longer in Z, without affecting other items
Re: Feature request - unlock XYZ Scale for Geometry - instead of Transform
« Reply #1 on: February 23, 2022, 02:13:36 pm »
+1
« Reply #2 on: February 28, 2022, 12:42:59 pm »
Hi Morne,
Thanks for the suggestion. We've had a chat here and decided that for the moment our UI is already quite large, so we'd prefer not to add additional controls that replicate a feature that could be achieved relatively easily using other means. In this case, you should be able to scale the geometry by selecting the source objects. Alternatively, you might be able to do something with Forest Effects. The attached Forest Effects file allows you to scale a subset of the geometry list. Set the range from the geometry list using GeomListStart and  GeomListEnd. The geometry list counts from the top down starting at 0.
I hope that helps,
