Author Topic: Clusters  (Read 3584 times)
JT9354
Clusters
« on: February 23, 2016, 03:56:58 pm »
when I use clusters mode I can't find a way to group objects together in the same cluster. think of some random seeds of the same flower, they should appear in the same cluster. IMO setting the same color ID should do the trick. I know I could draw color maps for distribution but I want it do do in clusters mode too.
tnx
boris
« Last Edit: February 23, 2016, 04:06:12 pm by Paul Roberts »
Re: Clusters
« Reply #1 on: February 23, 2016, 04:21:46 pm »
I would suggest you to give a try the latest beta (Forest Pack Pro 5.0.3 beta) with such feature implemented.
Distribution->Diversity Map and Clusters now recognize multiple models with the same color ID, handling them as a group with their own Probability values. / * To keep compatibility with existing scenes, this feature is applied only on new FP objects. / * This feature is not compatible with Areas->Select models. In this case, the previous behaviour is applied (using only the first color ID match).
