Author Topic: Forest Lister  (Read 9293 times)
Bobby Parker
Forest Lister
« on: June 12, 2024, 06:34:58 pm »
It doesn't do anything except bring a panel up on the left
Re: Forest Lister
« Reply #1 on: June 13, 2024, 10:21:32 am »
Hello Bobby,
Thanks for getting in touch. Could you provide a screen shot and let us know which version of Forest Pack you are using so we can try to understand the problem.
Many thanks,
Bobby Parker
Re: Forest Lister
« Reply #2 on: June 14, 2024, 12:15:49 am »
I am using the latest.
Re: Forest Lister
« Reply #3 on: June 14, 2024, 10:26:11 am »
I would suggest you "reset" 3ds max by deleting your User files. To remove the user profile:
  • Ensure that the 3ds max is not running.
  • Navigate to the following path: C:\Users%yourUsername%\AppData\Local\Autodesk\3dsMax\2019 - 64bit\ENU
  • Rename the ENU folder to ENU_Old.
When 3ds max is launched a new ENU folder will be created. If the issue has not been resolved, you can revert to the previous settings by deleting the new ENU folder and renaming the old one back to what it was.
Just to inform you, we released Forest Pack Pro 9.0.2b yesterday, which includes a fix for the tooltip and toolbar button mismatch.
Bobby Parker
Re: Forest Lister
« Reply #4 on: June 14, 2024, 06:20:01 pm »
I just updated again and it is now working
