Author Topic: Forest Custom Edit.  (Read 4737 times)
CgRod
Forest Custom Edit.
« on: April 29, 2013, 11:04:31 pm »
I have a little doubt, maybe something I'm doing wrong
I want to put a group of trees in specific locations, then apply the forest Custom Edit, select the trees that I will apply, as custom mesh and then the tree editor, select the objects pivot to center trees. (280 items)
the only problem is that I get just a tree,but i added 4 at the list, change the percentages and nothing happens.
not had this problem with previous versions.
well I hope I can help.
regards
Re: Forest Custom Edit.
« Reply #1 on: April 30, 2013, 08:42:06 am »
In the latest releases, the behaviour of Creation Tools is defined by the selector Add Item->Model/Random/Sequence (top of Tree Editor). Just select Random mode before creating the items.
Alternatively, once created, you can select all items and use the Properties->Randomize button.
