Toggle navigation
Login
Register
Forest Pack
Forest Pro (*)
Follow disp. surf. not working with Vray Distance tex.
« previous
next »
Print
Pages: [
1
Author
Topic: Follow disp. surf. not working with Vray Distance tex. (Read 2930 times)
RealViz
Sr. Member
on:
April 29, 2020, 04:49:07 pm »
I want to use vray distance tex. for displace surface, it working with Vray Disp. mod. But the same vray distance tex. not working with FP in effect :-(
attachement: jpg and Max file (2020).
Logged
ITOOSOFT
Hero Member
Re: Follow disp. surf. not working with Vray Distance tex.
Reply #1 on:
April 29, 2020, 06:17:55 pm »
Hi!
Thanks for the question. Please take a look at the attached in which I have modifier the Forest Effect slightly. The issue appeared to be related to the fact that the V-Ray Distance Texture does not use UVW coordinates but the effect was using the surface's UVW's to read the texture information. I have updated it so that it now uses the position of the item instead. Please note that in order for this to work, the Forest Object's location should be set to the world origin.
All the best,
Last Edit: April 29, 2020, 06:20:59 pm by Paul Roberts
Logged
RealViz
Sr. Member
Reply #2 on:
April 29, 2020, 06:44:55 pm »
Thanks! I think that UVW is the problem, but Im not sure. Is there any chance to put this in Efects Lib.?
Thx again
Logged
ITOOSOFT
Hero Member
Reply #3 on:
May 01, 2020, 01:00:03 pm »
Glad that helped out. Sure, I think we can add it to the library.
All the best,
Logged
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
