Author Topic: forect object is ways away from center on creation  (Read 4049 times)
mitviz
    • mitviz
« on: October 10, 2018, 07:28:40 am »
after i click the land object forest object creates but far away from the mesh itself, why is this?
Professional architectural renders
Re: forect object is ways away from center on creation
« Reply #1 on: October 10, 2018, 08:07:45 am »
Probably pivots are translated for Your scattered objects.
If something is not as expected we recommend to try these troubleshooting steps:
  • Check Pivot placement for scattered objects
  • Reset XForm for surface object
  • Make sure surface normals are facing up
  • delete forest_templates layer and recreate ForestPack object again
If that does not help,- please share Your scene here or  use this form to contact us if You can't attach files publicly.
Also You can use WeTransfer if compressed file is bigger than 6MB and paste the link in message.
mitviz
    • mitviz
« Reply #2 on: October 11, 2018, 03:55:20 am »
ok everything else was ok, deleting the forest template layer did the trick
