Forest Pack => Forest Pro (*) => Topic started by: IT1371 on April 10, 2014, 11:23:51 am
Just installed Forest 4.2.2 and the following issue happened:
All existing projects drop XREFs of presets when opened. When fixed the workstation renders just fine but the nodes render empty buckets on forest object.
I added new user paths to all nodes but yet they seem to ignore it.
Meanwhile reverted back to 4.1.6
Max Design 2014.
Vray 2.4
Windows 8.1
(ws and each node)
We had simular issue and manually deleting cashe libraries on the nodes resolve the issue.
Search for the folder "vray_assets_cache" on the node.
/3dpixel
If you upgraded from 4.0 or older, please see the following FAQ entry (http://forum.itoosoft.com/index.php?topic=1719.0)
Solved.
Thank you :)
