Author Topic: Unknown system exception error on loading scene with Forest object  (Read 7631 times)
Ruud3DV
I'm getting a dialog popup with 'Unknown system exception' when loading a scene containing a Forest object with manually placed cars.
Any idea why this happens or how to fix this? Below the MaxScript Listener output.
Code: [Select]
Welcome to MAXScript.
-- Error occurred in PxIsPhysicsObject(); filename: C:\Program Files\Autodesk\3ds Max 2016\stdplugs\stdscripts\(MassFX)\px_globals.ms; position: 33992; line: 1182
--  Frame:
--   n: $Forest-autos-placed (4)
--   called in i loop; filename: C:\Program Files\Autodesk\3ds Max 2016\stdplugs\stdscripts\(MassFX)\px_watcher.ms; position: 2050; line: 94
--  Frame:
--   m: undefined
--   i: $Forest-autos-placed (4)
--   called in px_filePostOpen(); filename: C:\Program Files\Autodesk\3ds Max 2016\stdplugs\stdscripts\(MassFX)\px_watcher.ms; position: 2189; line: 103
--  Frame:
--   curType: 5
--   pxType: undefined
--   scale: undefined
--   called in anonymous codeblock
--  Frame:
>> MAXScript Callback script Exception:
-- Unknown system exception <<
Re: Unknown system exception error on loading scene with Forest object
« Reply #1 on: July 05, 2017, 09:57:27 am »
First let me mention, that's most probably not related to the Forest Pack plug-in at all (please feel free to do a quick test using Forest Tools and export all distributed geometry to instances - this way you can easily check, if the problem is related to Forest object(s) or not).
As far as I know, PhysX (MassFX) might have issues with groups being used in scenes and Ungroup these can help. Anyway, I would encourage you to contact directly Autodesk regarding this problem as I'm afraid we can't do much more in this case. Thanks for your comprehension.
Best regadrs,
Ruud3DV
« Reply #2 on: July 05, 2017, 01:49:09 pm »
Thanks for the reply, I'll look into it and report back.
