Author Topic: Render Slave install after 6.1.2  (Read 4460 times)
UN4698
« on: December 20, 2019, 12:02:15 am »
Render Slaves don't render Forest Pack after 6.1.2 update.
Is there a lic change?  How do you set up the render slaves?
Vray distributed rendering worked fine this morning.  Then I made the mistake of updating FP (on all machines), and now none of the slaves will render FP.
« Last Edit: December 20, 2019, 07:14:03 am by UN4698 »
Re: Render Slave install after 6.1.2
« Reply #1 on: December 20, 2019, 01:17:00 pm »
I am sorry to hear You are facing these issues.
There were no licensing changes between these versions.
I just checked and salve works fine with latest FP.
I would recommend You to check our network rendering troubleshooting guide.
UN4698
« Reply #2 on: December 20, 2019, 04:10:11 pm »
I've checked all these things.  It was working fine minutes before the update and hasn't worked since.  I upgraded again to 6.2.2.  I uninstalled it and reinstalled it 3 times.  I can't figure out how to roll back to an older version.  I do think something strange is going on because I couldn't find anyone else post the same issue.  Is there an error log or something that would give more info?
« Reply #3 on: December 20, 2019, 04:25:39 pm »
Have You read the link i gave You:
Is it A or B in Your case?
A) Installation error.
B) Missing textures/proxies.
Roll back to an older version? Just reinstall older version on workstation + render nodes.
UN4698
« Reply #4 on: December 20, 2019, 06:45:35 pm »
After multiple restarts of all computers it is finally working again.  No other changes made.
« Reply #5 on: December 22, 2019, 10:25:14 am »
Hopefully with 6.2.2 ?
Thanks for letting us know, what helped in Your case. Maybe it will be helpful for future cases.
