Author Topic: Forest 9.3.4 not working properly in Max 2022  (Read 51 times)
Shawn Olson
  • Wall Worm
    • Wall Worm
« on: January 14, 2026, 09:56:43 pm »
I installed FP 9.3.4 recently. It seems to work correctly in Max 2026, but in 2022 most of the rollouts are missing and it won't render. It may not be rendering because of exceeding max faces etc, but I don't have access to the rollouts to control that. See attached image. In 2022 I'm only seeing the Distribution and General rollouts.
Shawn Olson
Product Management Team @ Autodesk for 3ds Max & Maya
Developer of Wall Worm Tools
Shawn Olson
  • Wall Worm
    • Wall Worm
Re: Forest 9.3.4 not working properly in Max 2022
« Reply #1 on: January 14, 2026, 10:02:21 pm »
I discovered the general options that allowed showing more rollouts. Note that I had never touched those options and it was only when installing this update did the rollouts disappear. In any event, the rollouts are back and I can properly use FP again.
Shawn Olson
« Reply #2 on: January 15, 2026, 08:31:18 am »
Hi Shawn,
Thanks for reporting this. If this situation occurs, you can re-enable these rollouts from General > Global Settings. Additionally, they can be configured or reset in the forestpack.ini configuration file.
By default, this file is located here:
C:\Users<yourUsername>\AppData\Local\Autodesk\3dsMax<your3dsMaxVersion>\ENU\en-US\plugcfg
I hope this helps.
