Author Topic: Forest animated custom object doesn't render.  (Read 3729 times)
DN1876
« on: January 29, 2020, 06:28:57 pm »
I was following the Randomising Procedural Objects with Forest Pack (intermediate) tutorial and for some weird reason the animated forest object items don't render at all.
The original items render fine, I see the animated item in my viewport but they render black.
I have checked units, reset xform at surface,areas, scattered geometry.
I have checked materials on all items.
Does anyone have any clue what else could it be?
PS. in the attachment I have disabled the single items to check only the animated one.
I am using 3dsmax 2020 and Corona 5.
Thanks in advance!
« Last Edit: January 30, 2020, 11:40:45 am by DN1876 »
Re: Forest animated customobject doesn't render.
« Reply #1 on: January 30, 2020, 07:33:41 am »
Unfortunately Corona is not yet supported for this feature.
Please refer to ForestPack documentation  to learn more which features are supported and which are not.
DN1876
« Reply #2 on: January 30, 2020, 08:43:38 am »
Thank you for your reply, I hope it will be supported soon because is a very handy feature.
If I just create an forest object patch without animation it will work?
« Reply #3 on: January 30, 2020, 10:00:39 am »
Corona renderer itself is supported. Just animated geometry is not.
DN1876
« Reply #4 on: January 30, 2020, 10:27:16 am »
OK, maybe i didn't explained it properly.
I have made another Forest pack scene for test. I have 4 plants for scattering. Then I create a forest object patch which I don't animate at all.
If I try to scatter the patch in a new Forest it doesn't render neither at viewport neither at Corona Renderer. If I delete the patch and add the 4 items it renders properly.
So in order to understand it Corona isn't supported even in creating simple static patches of items?
Thank you for your time.
« Reply #5 on: January 30, 2020, 11:39:51 am »
Thanks. Now I understand. Fix is described in this post.
DN1876
Re: Forest animated custom object doesn't render.
« Reply #6 on: January 30, 2020, 11:45:27 am »
Thank you very much!
