Forest Pack => Forest Pro (*) => Topic started by: DN1876 on January 29, 2020, 06:28:57 pm
Title: Forest animated custom object doesn't render.
Post by: DN1876 on January 29, 2020, 06:28:57 pm
I was following the Randomising Procedural Objects with Forest Pack (intermediate) tutorial and for some weird reason the animated forest object items don't render at all.
The original items render fine, I see the animated item in my viewport but they render black.
I have checked units, reset xform at surface,areas, scattered geometry.
I have checked materials on all items.
Does anyone have any clue what else could it be?
PS. in the attachment I have disabled the single items to check only the animated one.
I am using 3dsmax 2020 and Corona 5.
Thanks in advance!
Title: Re: Forest animated customobject doesn't render.
Post by: Rokas on January 30, 2020, 07:33:41 am
Unfortunately Corona is not yet supported for this feature.
Please refer to ForestPack documentation   (https://docs.itoosoft.com/forestpack/requirements)to learn more which features are supported and which are not.
Post by: DN1876 on January 30, 2020, 08:43:38 am
Thank you for your reply, I hope it will be supported soon because is a very handy feature.
If I just create an forest object patch without animation it will work?
Post by: Rokas on January 30, 2020, 10:00:39 am
Corona renderer itself is supported. Just animated geometry is not.
Post by: DN1876 on January 30, 2020, 10:27:16 am
OK, maybe i didn't explained it properly.
I have made another Forest pack scene for test. I have 4 plants for scattering. Then I create a forest object patch which I don't animate at all.
If I try to scatter the patch in a new Forest it doesn't render neither at viewport neither at Corona Renderer. If I delete the patch and add the 4 items it renders properly.
So in order to understand it Corona isn't supported even in creating simple static patches of items?
Thank you for your time.
Post by: Rokas on January 30, 2020, 11:39:51 am
Thanks. Now I understand. Fix is described in this post (https://forum.itoosoft.com/forest-pro-(*)/nested-forest-corona-render/msg22288/#msg22288).
Title: Re: Forest animated custom object doesn't render.
Post by: DN1876 on January 30, 2020, 11:45:27 am
Thank you very much!
