Author Topic: Forest Animation - Random Samples  (Read 3330 times)
JC4004
« on: June 15, 2020, 11:00:51 am »
Can you let me know if I'm missing something?
I have an animated proxy with an animated map.
Problem(underAnimation tab-forest pro):
When I use random samples with a time offset and count value. It offsets the proxy but does not offset applied the animated map(relative to each of the mapped proxys). Works fine if I use "Follow Geometry"
Can you let me know if this is possible to fix?
Cheers,
Keith
« Last Edit: June 15, 2020, 12:29:18 pm by JC4004 »
Re: Forest Animation - Random Samples
« Reply #1 on: June 15, 2020, 02:38:56 pm »
Hi Keith,
ForestPack samples geometry for now.
We will check if that can be extended to material as well.
Thanks for suggestion.
